E hvað ? og M hvað ?
Postby O.Johnson » Sun 07. Dec 2003 03:53
Fann þetta á síðu sem útskýrir þetta allt saman.
Why do they call my car an “E” something when it’s a 325i, 535i, etc..?
When you hear you car being referred to as an E classification, what they are referring to is the body style of a particular car. For instance, BMW has produced a 3 Series model from 1976 to 2003. Naturally, the body style changes over time, so to avoid confusion; they refer to the 1976-83 3 Series as an E21, the 1984-91 cars as E30, 1992-99 cars as E36, and the present models as the E46. Keep in mind that certain early cars do not have an E number. Here’s a break down of the “E” numbers as well as the early designations
114 1602 – 2002tii
118 1500, 1600-4, 1800, 1800tii
120 2000C/CS/CA
121 2000, 2000ti, 2000tilux
E3 2500 – 3.3Li
E6 1600, 1800, 2000 touring
E9 2500CS – 3.0 CSi
E12 5 Series cars from 1974 to 1981
E21 3 Series cars from 1976 to 1983
E23 7 Series cars from 1977 to 1986
E24 6 Series cars from 1976 to 1989
E26 M1
E28 5 Series cars from 1981 to 1987
E30 3 Series cars from 1984 to 1991
E31 8 Series cars from 1989 to 1997
E32 7 Series cars from 1986 to 1994
E34 5 Series cars from 1988 to 1995
E36 3 Series cars from 1992 to 1999
E36/5 318ti
E36/7 Z3 Roadster
E38 7 Series cars from 1994 to 2001
E39 5 Series cars from 1995 to 2001
E46 3 Series cars from 1999 to 2003
E52 Z8 Roadster
E53 X5 SAV
E65 7 Series cars from 2002 (short wheelbase)
E66 7 Series cars from 2002 (long wheelbase)
E85 Z4 Roadster
What do these letters on the back of my car mean?
Traditionally BMW has used a series of letters to denote differences between models. For instance “is” would mean injected sports. Here’s a breakdown of the letters and what they mean. Keep in mind that various BMW’s used combinations of these letters. However, these letters are the most common.
i Fuel Injected
is Fuel Injected – Sports. Sports package, with better suspension, sway bars, etc..
ic Fuel Injected – Cabriolet, Convertible models
e ETA model. Built by BMW as efficiency-minded cars during the 1980’s
es ETA – Sports, ETA model with sports package.
Ci Fuel Injected – Coupe. This designation is used on most modern BMW’s
Csi Fuel Injected – Sports Coupe.
iT Fuel Injected – Touring. BMW’s station wagon.
iX Fuel Injected – All Wheel Drive.
Ti Fuel Injected – Touring Compact.
Tii Fuel Injected – Touring International. Used only on early cars.
M Motorsports. M3, M5 for example, BMW’s hot rod.
L Luxury. Basically a normal car fitted with full leather and all options, i.e. L6, L7
What is the difference between a 525i and a 535i? A 325i and a 328is?
With the exception of the early cars, 1600, 1800, 2002 etc., BMW has usually used a three digit numbering system to identify models. The first number refers to the Series, for instance 328is would be a 3 Series, while a 740iL would be a seven series. The last two numbers are typically the engine displacement of a particular model, So, a 328is Would mean a 3 Series, Fuel Injected 2.8 liter engine with the sports package. The 740iL would refer to a 7 Series, Fuel Injected 4.0 liter engine with a luxury package. Keep in mind that the last two numbers do not always mean actual engine displacement.
What are they talking about when they say my 325i has an M20?
Usually BMW uses an M or S designation to identify their engines. In most cases several different engines would be used in a particular series, such as a 2.8, 3.5, and 4.0 all being available in the 5 Series. Here is a breakdown of the various designations and engines. For each engine listed, there is usually a displacement code. For instance, an M20B27 would be an M20 engine with a 2.7L displacement.
These are old engine codes that are no longer used
M41 4 Cylinder 1.6L DIDTA carburetor
M42 4 Cylinder 1.8L DIDTA carburetor
M49 6 Cylinder 3.4L 24-valve Motorsport twin-cam
M60 6 Cylinder 2.0L and 2.3L carburetor or fuel injection
M68 6 Cylinder 2.5L and 2.8L carburetor
M69 6 Cylinder 3.2L fuel injection
M86 6 Cylinder 2.8L fuel injection (L-Jetronic)
M90 6 Cylinder 3.5L
M92 4 Cylinder 1.8L fuel injection (K-Jetronic)
M99 4 Cylinder 1.8L 2B4 carburetor
M102 6 Cylinder 3.2L turbocharged
These are the current engine codes used
M10 4 Cylinder 1.8L or 2.0L single overhead cam, timing chain.
M20 6 Cylinder 2.0, 2.3, 2.5 or 2.7L single overhead cam, timing belt.
M21 6 Cylinder 2.4L Diesel single overhead cam, timing belt.
M30 6 Cylinder 2.8, 3.0, 3.2, or 3.4L single overhead cam, timing chain.
M40 4 Cylinder, DOHC
M41 4 Cylinder Diesel
M42 4 Cylinder 1.8L DOHC
M44 4 Cylinder 1.9L DOHC
M50 6 Cylinder 2.0, 2.3, or 2.5L DOHC
M50TU 6 Cylinder 2.0, 2.3, or 2.5L DOHC, VANOS variable intake
M51 6 Cylinder Diesel
M52 6 Cylinder 2.0, 2.3, 2.5, or 2.8L DOHC, VANOS variable intake
M52TU 6 Cylinder 2.5 and 3.0L DOHC, VANOS variable intake and exhaust
M54 6 Cylinder 2.5 and 3.0L DOHC, VANOS variable intake and exhaust
M56 6 Cylinder 2.5L DOHC, Dual VANOS, SULEV (low emissions)
M60 8 Cylinder 3.0 or 4.0L
M62 8 Cylinder 3.5 or 4.4L
M70 12 Cylinder 5.0L
M73 12 Cylinder 5.4L
M88 6 Cylinder 3.5L, 24 valve Motorsport engine (only in the BMW M1)
M88/3 same as above, but for all other vehicles
S14 4 Cylinder 2.3L DOHC Motorsport engine (only in the E30 M3)
S38 6 Cylinder 3.6 or 3.8L DOHC Motorsport engine
S50 6 Cylinder 3.0 or 3.2L DOHC, Dual VANOS Motorsport engine (Non-US M3)
S50US 6 Cylinder 3.0 or 3.2L DOHC, Single VANOS Motorsport engine (US M3)
S52 6 Cylinder 3.2L DOHC, Dual VANOS Motorsport engine
S54 6 Cylinder 3.2L DOHC, Dual VANOS Motorsport engine
S62 8 Cylinder 5.0L quad cam, quad VANOS Motorsport engine
S70 12 Cylinder 5.6L Motorsport engine
http://www.pelicanparts.com/bmw/techarticles/JF-Tech/BMW_Designation_faq.htm
O.Johnson
Postby Jss » Mon 08. Dec 2003 09:41
Gaman að þessu en finnst ég hafa séð þetta hérna áður :?
Jóhann
Jss
Postby Logi » Mon 08. Dec 2003 14:40
Jss wrote:Gaman að þessu en finnst ég hafa séð þetta hérna áður :?
Kannski ekki nákvæmlega þessi tafla, en eitthvað mjög svipað þessu!
Logi
Postby Kristjan » Mon 08. Dec 2003 15:16
Er til E34 520 IA?
Postby arnib » Mon 08. Dec 2003 15:23
Kristjan wrote:Er til E34 520 IA?
Að sjálfsögðu :?:
BMW E46 328i
arnib
Postby Kristjan » Mon 08. Dec 2003 15:27
Málið er sko að félagi minn á E34 520 en hann er sjálfskiptur, með tudda. En hann er skráður IS...
Postby Jss » Mon 08. Dec 2003 15:41
Það er ekkert óþekkt að skráningar á bílum misfarist, stundum sem VIN númerin misfarast og svo framvegis og svo framvegis.
Jóhann
Jss
Postby arnib » Mon 08. Dec 2003 15:57
Gæti verið já að það hafi misfarist eitthvað,
en gæti líka einfaldlega verið að hann heiti ekki "A".
T.d. heita nýjir E46-ar í dag aldrei "A" sama hvaða skiptingu þeir eru með.
BMW E46 328i
arnib
Postby Moni » Mon 08. Dec 2003 21:55
Það var einhver sem sagði mér að "A-ið" þýddi leðurinnrétting, minnir að það hafi verið einhver bílasali, ég sagði að það væri "automatic" en hann sagði nei, það er innréttingin... Hvor okkar er að bulla?? :D
"L-ið", það er talað um L6 og L7, er ekki verið að meina t.d. 740iL og 750iL???
'Eg hef heyrt að þau L sem ég er að tala um þýði "Long", en það meikar smá sens, því að 740iL er lengri á milli hjóla en venjulegur 740i...
(correct me if i´m wrong)
Gunnar Hans - Alltaf á löglegum hraða :twisted:
-BMW 318i E36 ´93 - Seldur...
-Honda Prelude 2,0 4th-Generation - Seldur...
-Honda Accord 2,0 EXE
Moni
Postby arnib » Mon 08. Dec 2003 22:52
Moni wrote:Það var einhver sem sagði mér að "A-ið" þýddi leðurinnrétting, minnir að það hafi verið einhver bílasali, ég sagði að það væri "automatic" en hann sagði nei, það er innréttingin... Hvor okkar er að bulla?? :D
A-ið þýðir sjálfskipting, en er ekki alltaf notað.
Þú gætir séð sjálfskiptan bíl með ekkert A,
en þú munt aldrei sjá A á beinskiptum, leður eða ekki leður :)
Ég man eftir umræðu um þessa L6 og L7 bíla og mig minnir að þetta hafi verið sérútgáfur með mjög miklum búnaði eða álíka?
BMW E46 328i
arnib
Re: E hvað ? og M hvað ?
Postby Jss » Tue 09. Dec 2003 09:25
O.Johnson wrote:L Luxury. Basically a normal car fitted with full leather and all options, i.e. L6, L7
Þar hafið þið þetta, ÁrniB hefur rétt fyrir sér eins og oft áður. :D
Jóhann
Jss
Postby Logi » Tue 09. Dec 2003 12:56
En það voru bara Ameríku-bílar, ekki satt?
Logi
