Top E30 M3's
Top E30 M3's
Postby maxel » Fri 19. Oct 2007 16:36
Hartge M3 H 35-24 (BMW M88 3.5L)
Peak hp - 300 hp (6800rpm) 6 cylinder
Peak torque - 362 nm (4500rpm)
Displacement - 3453cc
Bore/stroke - 93.4 x 84mm
Compression - 9.91:1
0-100kmh - 5.9
Top speed - 256kmh
Weight - 1416kg
ZF 25% LSD
Final drive ratio - 2.93:1 40% LSD
Transmission
Getrag 265
5 speed manual.
Gear Ratio - 3,72
2,40
1,77
1,26
1,00
R n/a
5th gear direct drive
Production Dates - n/a
Retail in US$ - In Germany $61,041
Total Produced - n/a
Alpina B6 3.5 S (BMW M30 3.5L)
Peak hp - 260 hp (5900) 6 cylinder
Peak torque - 328 nm (4000rpm)
Displacement - 3430cc
Bore/stroke - 92 x 86mm
Compression - 10.0 : 1
0-100kmh - 6.0
Top speed - 245kmh
Weight - 1318kg
ZF 25% LSD
Final drive ratio - 2.79:1
Transmission
Getrag 265
5 speed manual.
Gear Ratio - 3,72
2,40
1,77
1,26
1,00
R n/a
Retail in US$ - In Germany $50,992
Total Produced - 62
Schnitzer S3 Sport (S14 2.5L)
Peak hp - 240 hp w/c
245 hp n/c (6750rpm)
Peak torque - 278 nm (4700rpm)
Displacement - 2431cc
Bore/stroke - 93.8 x 88mm
Compression - 10.5:1
0-100kmh - 6.7
Top speed - 253kmh
Weight - n/a
ZF 25% LSD
Final drive ratio - n/a
Transmission
Getrag 265
5 speed manual.
Gear Ratio - n/a
Retail in US$ - n/a
Sport Evolution (Evo III) (S14 2.5L)
Peak hp - 238 hp w/c (7000rpm)
Peak torque - 245 nm (4750rpm)
Displacement - 2467cc
Bore/stroke - 95 X 87mm
Compression - 10.2:1
0-100kmh - 6.2
Top speed - 248kmh
Weight - 1198kg
ZF 25% LSD
Final drive ratio - 3.15:1
Transmission
Getrag 265
5 speed manual.
Gear Ratio - 3,72
2,40
1,77
1,26
1,00
R n/a
Production Dates - Jan. 90 - March 90
Retail in US$ - In the U.K. $55,406
Total Produced - 600
Sport Evolution Group 'A' (S14 2.5L)
Peak hp - 330 hp 3w/c (8500rpm)
Peak torque - 297 nm (7500rpm)
Displacement - 2493cc
Bore/stroke - 95.5 X 87mm
Compression - 12.0 : 1
0-100kmh - 4.3
Top speed - 282kmh
Weight - 939kg
ZF 25% LSD
Final drive ratio - 3.15:1 to 5.28:1
Transmission
Getrag 265
5 speed manual.
Gear Ratio - 2.337
1.681
1.358
1.150
1.00
R 2.66
Production Dates - May 1988 - July 1989
Retail in US$ - In Germany $116,127
Svo voru líka original M3 Euro Spec og U.S. Spec, Cabriolet (alveg handsmíðaðir,
Europa Meister, Cecotto, Ravaglia, Evolution I, Evolution II og Group 'A' (2.3l)
Postby maxel » Fri 19. Oct 2007 17:30
Nokkrar fleiri myndir af E30 M3
Ofan: Sport Evolution (Evo III)
Ofan: Ekki alveg viss, ábyggilega Group 'A'
Ofan: M3 Cabriolet, allir Cabriolet bílarnir voru handsmíðaðir (afsakið stærðina)
Ofan: Flott cut-away mynd af líklegast Group 'A'
Re: Top E30 M3's
Postby trolli » Fri 19. Oct 2007 18:58
0-100kmh - 4.3 :shock: 4.3..
Top speed - 282kmh
Weight - 939kg
ZF 25% LSD
trolli
Postby Angelic0- » Fri 19. Oct 2007 19:05
ACS bíllinn heillar mig hvað mest..
Postby maxel » Fri 19. Oct 2007 19:13
Angelic0- wrote:ACS bíllinn heillar mig hvað mest..
Postby Fieldy » Fri 19. Oct 2007 20:30
BMW E34 525i '89
BMW E30 318i '89(r.i.p)
Fieldy
Postby Zeus » Fri 19. Oct 2007 20:32
Afhverju er þetta í OFF-Topic? Skemmtilegur þráður :wink:
Zeus
Postby maxel » Fri 19. Oct 2007 20:47
bara einhver að færann :D
Re: Top E30 M3's
Postby maxel » Fri 19. Oct 2007 20:49
trolli wrote:------------------------------------------------------------------------------
Top speed - 282kmh
Weight - 939kg
ZF 25% LSD
enda 939 kg og 330hp :)
Postby Djofullinn » Fri 19. Oct 2007 20:54
Flottustu bílar í heimi 8)
Postby elli » Fri 19. Oct 2007 21:10
Mér finnst þetta Warsteiner paint job alltaf fjandi flott (eða þessir Warsteiner merktu bílar)
Jú og ekki má gleyma Jagermeister lookinu það er líka flott.
Elli M1 fan
E32 750I '91 >
elli
Postby maxel » Sat 20. Oct 2007 16:26
mér langar samt mest í hartgeinn því han ner með m1 vél :)
Postby Aron Fridrik » Sat 20. Oct 2007 17:44
ég er mest hrifinn af hartge bílnum..
Postby HPH » Sat 20. Oct 2007 17:59
Alveg Orginal Evo 3 8)
G01 X3
HPH
Postby Alpina » Sat 20. Oct 2007 18:01
Cabrio S38B38 :roll:
