i sambandi við e-36 bila
Postby bakari22 » Tue 20. Mar 2007 11:00
ég var ad pæla svoldid eins og flestir kanast við á ég e-36 325 bmw 94 árgerd !
mér langar ad vita hvort veit enhver, og hvort það er hægt, ad breita tungumál i tolfuni á skjánum, sem er undir geislaspilaranum ?
og hverni madur geri það ef það er hægt ?
það er á þisku enn ég kan ekki ord á þisku hvort er hægt ad breita á ensku ?
bakari22
Postby mattiorn » Tue 20. Mar 2007 12:23
Tekið af: http://www.m5board.com/vbulletin/archive/index.php/t-6767.html
Getting into the Test Codes:
Push OBC buttons 1000 and 10 together. You will see the word Test. By pressing a combination of the 10 and 1's you can enter Test Codes from 1 to 21. After entering the number press R/S and you will get a continuous display of the test function. To cancel, just press any of the OBC function keys.
List of Available Tests:
Test Number Description
1 Display Test (all LCDs and LEDs activate)
2 Current Consumption in litres / 100 km
3 Current Consumption in litres / hour
4 Average consumption (used in calculating range)
5 Current Range
6 Not used (this function is active on some, but not sure of the purpose)
7 Fuel Remaining in Tank (litres)
8 Current speed (km/h)
9 System Voltage at Terminal R
10 Country / Language
11 Units / am.pm
12 Average speed (km/h) for calculating ETA
13 ETA
14 Date of software / mask of OBC
15 Production Diagnosis
16 Production Diagnosis
17 Display Vehicle Specific Data
18 Alarm Changeover (continuous vs. intermittent)
19 Lock / Unlock all functions (Sum of month and date to unlock or lock)
20 Correction Factor for OBC Fuel Consumption
21 Reset all defect codes, date and time
mattiorn
Postby Aron Fridrik » Tue 20. Mar 2007 14:29
er þetta líka á litlu tölvunni ?
Postby Angelic0- » Tue 20. Mar 2007 15:53
aronisonfire wrote:er þetta líka á litlu tölvunni ?
Yub ;)
Postby mattiorn » Tue 20. Mar 2007 16:09
Google veit ALLT
mattiorn
Postby Aron Fridrik » Tue 20. Mar 2007 16:37
Yub ;)
nei :cry: virkar ekki hjá mér..
hm
Postby bakari22 » Tue 20. Mar 2007 19:07
ég á eftir ad prufa það læt ykkur vita svo ! takk
bakari22
