2001 ALPINA B3 3.3
2001 ALPINA B3 3.3
Postby ta » Mon 16. Oct 2006 13:53
engine Inline 6
Der 3.3-Motor ist ein Teilemotor,
der vom Kopf auf dem M52 basiert, der Block vom S52B32
valvetrain 4 Valves / Cyl
displacement 3300 cc / 201.4 cu in
bore 86.4 mm / 3.4 in
stroke 93.8 mm / 3.69 in
compression 10.2:1
power 208.8 kw / 280.0 bhp @ 6200 rpm
hp per litre 84.85 bhp per litre
bhp/weight
torque 335.0 nm / 247.1 ft lbs @ 4500 rpm
redline 7200 rpm
drive wheels Front Engine / RWD
body / frame Unit Steel
front brakes Vented Discs
rear brakes Vented Discs
front wheels F 45.7 x 40.6 cm / 18.0 x 16.0 in
rear wheels R 45.7 x 43.2 cm / 18.0 x 17.0 in
front tire size F 225/40ZR-18
rear tire size R 255/35ZR-18
final drive 3.64 ekki læst
top speed 267.0 kph
0 - 100 6.9 seconds
mílan, 14 jul 2007: 14.231
BMW ALPINA B3 3,3 Touring SWITCH-TRONIC**
Paintwork: orientblue-metallic
Leather Montana black
ALPINA-velours-floor mats anthrcite
ALPINA 3-spoke sport-leather-steering wheel
Speed control with multifunction key
Automatic gearbox
Dynamic stability control
Side airbag for driver and passenger
Side airbag for rear passenger
ITS head airbag for driver and passenger
Tyre-pressure monitoring
Outside mirror package
Green shade band-windscreen
Roof rails
Sliding-tilding-glas sunroof
Automatic dipping mirror
luxury wood "Myrte"
Smoker package
Seat-adjustor control, elecrical with memory for driver seat
BMW-sport-seats for driver and passenger
Seat heating for driver and passenger
Headlight washer system
Park distance control (PDC)
rain sensor
Xenon light
Automatic air condition incl. automatically recirculating air control
navigation system with TV and bord computer incl. radio Professional
Car telephon D-net with card-reader front
Radio: BMW Professional
CD-changer BMW 6 CD changer
HiFi-loudspeaker system Harman/Kardon
High gloss shadow line
Headlining antracite BMW Individual
Approved vehicle immobilisation system AZT/TÜV
Basisfahrzeuge für
den BMW/ALPINA B3 3,3 (B3 3,3 L), das BMW/ALPINA B3 3,3 Coupé (B3 3,3 C), das
BMW/ALPINA B3 3,3 Cabrio (B3 3,3 R) und den BMW/ALPINA B3 3,3 touring (B3 3,3 T)
sind: E46 der 330i = Motor E4/6
Basismotor ist der S52B32 (E36 M3 US; Graugußblock).
I will add that I found the self-learning of the auto box on the BMW extremely frustrating. It would learn "Granny mode" during my daily drive to work in heavy traffic, then when I wanted a spirited response, like pulling out into traffic on a roundabout in auto mode it would be in the wrong gear which could be a bit dodgy sometimes while it sorted itself out to change down. Because of that I mostly drove it in steptronic mode. In contrast to that, Alpina removed the self-learning function from the gearbox software, so it works the same way in auto all the time regardless.
ALPINA boxes behaves quite differently from the BMW.
The unique part from the ALPINA box is to hold onto a gear until the absolote rev limit of that gear irrespective of whether you lift (say in mid corner or not) this is titally unlike the BMW box which will change up in the same situation even in it's manual mode.
Frá BMW svona:
Vehicle information
Type code AW51
Type 330I (EUR)
Dev. series E46 (3)
Line 3
Body type TOUR
Steering LL
Door count 5
Engine M54
Cubical capacity 3.00
Power 170
Transmision HECK
Gearbox AUT
Colour ORIENTBLAU METALLIC (317)
Upholstery STANDARDLEDER/SCHWARZ (N6SW)
Order options
No. Description
205 AUTOMATIC TRANSMISSION
210 DYNAMIC STABILITY CONTROL (DSC)
249 MULTI-FUNCTION FOR STEERING WHEEL
255 SPORTS LEATHER STEERING WHEEL
261 SIDE AIRBAG FOR REAR PASSENGERS
265 TIRE PRESSURE CONTROL (RDC)
313 EXTERIOR MIRROR PACKAGE
320 MODEL DESIGNATION, DELETION
354 GREEN STRIPE WINDSCREEN
386 ROOF RAIL
403 GLAS ROOF, ELECTRIC
428 WARNING TRIANGLE
*31 INTERIOR RR VW MIRROR W AUT ANTI-DAZZLE
438 WOOD TRIM
441 SMOKERS PACKAGE
459 SEAT ADJUSTM., ELECTR. W MEMORY F DRIVER
481 SPORT SEATS F DRIVER/FRONT PASSENGER
502 HEADLIGHT WASHER SYSTEM
508 PARK DISTANCE CONTROL (PDC)
521 RAIN SENSOR
522 XENON LIGHT
609 NAVIGATION SYSTEM PROFESSIONAL
629 CAR TELEPHONE (GSM) W CARD READER FRONT
672 CD CHANGER BMW FOR 6 CDS
674 HIFI LOUDSPEAKER SYSTEM HARMAN KARDON
760 INDIVIDUAL HIGH-GLOSS SATIN CHROME
775 INDIVIDUAL ROOF-LINING ANTHRACITE
801 GERMANY VERSION 863 EUROPE/DEALER DIRECTORY
879 GERMAN/OWNERS HANDBOOK/SERVICE BOOKLET
920 ALPINA W/O REGISTRATION DOCUMENT
940 SPECIAL REQUEST EQUIPMENT
ta
Postby gstuning » Mon 16. Oct 2006 14:13
SWEETT
Postby Aron Andrew » Mon 16. Oct 2006 14:41
Til hamingju!
Sá þig einmitt á honum uppá braut í gær, virkilega flottur!
Er D5 seldur?
Postby Jss » Mon 16. Oct 2006 15:03
Til hamingju með þetta, hlaut að koma að því að þú fengir þér Alpina bifreið. ;)
Jóhann
Jss
Postby noyan » Mon 16. Oct 2006 15:09
Glæsilegur, til hamingju :!:
Magnús
noyan
Postby hlynurst » Mon 16. Oct 2006 15:10
Til hamingju með þennan bíl.
Stórglæsilegur! 8)
hlynurst
Postby ///MR HUNG » Mon 16. Oct 2006 17:06
Nohh töffer ertu...Hef verið með annað augað á þessum í marga mánuði.
///MR HUNG
Postby ta » Mon 16. Oct 2006 17:16
///MR HUNG wrote:Nohh töffer ertu...Hef verið með annað augað á þessum í marga mánuði.
gafts upp á að bíða eftir að þinn 330i færi á sölu.
annars hef ég verið utaní þessum frá því
hann kom til landsins, loksins gekk dæmið.
D5 er til sölu hjá Höfðahöllinni.
takk.
ta
Postby ///MR HUNG » Mon 16. Oct 2006 18:52
takk.
Enda hefðurðu þurft að bíða lengi :mrgreen:
///MR HUNG
Postby fart » Mon 16. Oct 2006 19:50
Congrats Torfi!
Postby iar » Mon 16. Oct 2006 20:49
Góður að grípa þennan! Virkilega flottur bíll! Til lukku! :D
Postby Benzer » Mon 16. Oct 2006 21:23
Til hamingju með flottann bíl...
Fleiri myndir....
BMW 750 il
BMW Z3
Jeep Grand Cherokee V8 99 árgerð
Husaberg 450 Götuprjónarinn
Benzer
Postby arnibjorn » Mon 16. Oct 2006 21:24
Sá þig á honum í gær... BARA flottur :)
Til hamingju með bílinn! 8)
Postby bimmer » Mon 16. Oct 2006 21:50
Flottur þessi - til hamingju!!!
Fleiri myndir takk.
Postby Alpina » Mon 16. Oct 2006 22:06
Urrrrrrrrr..
hvenær ætli minn draumur gangi upp
((((((((((( en til hamingju #### FEITT #### )))))))))))
Users browsing this forum: Google [Bot] and 27 guests
